How to let the BulkAttributeRenamer do substring?
  • Mar 26, 2018 11:34 AM UTC
  • 5 replies
  • 84 views
nielsgerrits
Forum|alt.badge.img+67
Is it possible to do a substring(0,10) with the BulkAttributeRenamer? I want to simulate truncating the columns as writing to shape does. I know I can do this with a SchemaMapper, this is my current workaround.
Best answer by david_r
You can use the regex replacement method. For example, this will truncate all attribute names to the first 10 characters:
  • Mar 26, 2018 11:42 AM UTC
Hi @nielsgerrits, yes it's possible. Try this.
Text To Find: ^(.{10}).*
String: \1
  • Mar 26, 2018 11:48 AM UTC
String: \1
You beat me to it! :-)
nielsgerrits
String: \1
Thanks! I knew it should be doable but gave up after a few tries.
nielsgerrits
Thanks for the effort!
