Open
Ability to import Postman Package into HTTPCaller
Related products:Transformers
lynne
  • lynne
    lynne
cjd111
When developing against APIs it is often common practice to test and get familiar with the API in postman before bringing it into your solution (FME). We have also found that it is becoming increasingly common for platforms to share how their API's work by sharing a postman package (JSON). I have found that sometimes an API will work in postman, but when you mimic the setup in the HTTPCaller, it doesn't work. Or its not always clear how the postman setup should be applied to the HTTPCaller configuration. A helpful solution, would be the ability to import configuration into the HTTPCaller, a postman package (JSON) file could be loaded in and used to populate the HTTPCaller configuration and parameters.
cjd111
  • May 26, 2022
Good to discuss this with you today @donatsafe​
bruceharold
Forum|alt.badge.img+17
  • May 26, 2022
What direction did you guys settle on? Something else I would like to see is for HTTPCaller to have a verbose mode where what goes down the wire can be captured (into an attribute?). Fiddler is a bear.
