How to insert a character into specific position for many attributes?
  • Mar 27, 2020 6:52 PM UTC
  • 459 views
I'm trying to update a large file with many attributes. The original file's attribute names followed a specific nomenclature with 4 alphanumeric chars, then an 'X', then followed by 3 digits. An example:
ZA01X001
The new file now has the 'X' stipped out, so the new example is:
ZA01001
My problem is that my workflow uses an AttributeManager to rename about 80 different attribute names from a separate lookup table that corresponds the attribute coded name to a variable name like so:
ZA01001 = Total Population with Medicaid Coverage
So this new file is throwing off my AttributeManager with the 'X' now gone. My question is, how can I use the BulkAttributeRenamer or other method to easily insert an 'X' into the 4th position of all attribute names?
Forum|alt.badge.img+54
  • Mar 27, 2020 7:06 PM UTC
Try this, regular expression replace - match the first 4 characters then replace with those 4 characters and an X
That worked perfectly! Thank you very much @ebygomm
