How to insert a character inbetween the string with different lentgh?
  • February 19, 2018
  • 255 views
Hello.I need to insert a dash into a phone number after first
digit. I know how to do it using attribute manager and text editor only
if the length of the number is always the same. In this case is not. Is there a code I can put instead of "X" to indicate the rest of the value? If I will put fixed number the outcome is incorrect because of mentioned before different string length.
Maybe there is other way?
Thanks,
Cheers
Best answer by david_r
You can use the following expression:
@Left(@Value(phone_no),1)-@Substring(@Value(phone_no),2)
You can also use the StringReplacer:
  • February 19, 2018
  • February 19, 2018
Thanks! It works ;]
