How to I extract information from XML fle
  • Dec 15, 2022 8:29 AM UTC
  • 97 views
Hello Sir/ Madam,
So I have a CityGML file, which is based on XML. In each of the 3D model, I would like to extract the attribute name and values. Basically, what I want is that those with gen:string attribute name and bldg are the values where I would like to retreive.
Here is a part of the file
<gen:stringAttribute name="BuildingStructureID">
    <gen:value>15169952</gen:value>
   </gen:stringAttribute>
   <gen:stringAttribute name="BuildingCSUID">
    <gen:value>3917120211T20050430</gen:value>
   <gen:stringAttribute name="BuildingID">
    <gen:value>1108233601</gen:value>
   <gen:stringAttribute name="ModelIdentityNumber">
    <gen:value>B391712021101062A0</gen:value>
   <gen:stringAttribute name="UUID">
    <gen:value>22fe4b82-05e8-44ec-91cc-3408862e240a</gen:value>
   <gen:stringAttribute name="BuildingStructureType">
    <gen:value>T</gen:value>
   <gen:stringAttribute name="BuildingNameEN">
    <gen:value>
    </gen:value>
   <gen:stringAttribute name="BuildingNameTC">
    <gen:value>
    </gen:value>
   <bldg:usage>Miscellaneous</bldg:usage>
   <bldg:measuredHeight>3.7001</bldg:measuredHeight>
I would like to extract the information with two attributes - Attribute_Name and Value,
Attribute_Name Value
BuildingStructureID 15169952
BuildingCSUID 3917120211T20050430
BuildingID 1108233601
Usage Miscellaneous
MeasuredHeight 3.7001
Is it possible to do that in FME? I tried to use XMLFlattener but with no luck. Any assistant would be gratefully appreciated.
I have attached one model sample in here.
Thank you very much.
itsmatt
Forum|alt.badge.img+48
  • Dec 15, 2022 8:46 AM UTC
FME has a CityGML reader. You can add a CityGML reader and just pick the 'Building' feature type. The attributes will be part of the building features.imageThe 'Measured Height' attribute is read into FME as "citygml_measured_height" as is shown in the screen shot. You can then use an AttributeManager to remove the unneeded extra attributes and rename any.
Thank you and sorry for this stupid question. I use Schema reader at the first place.
Ok, I will try to use CityGML reader.
Thanks for your help! 🙂
