How to get the geometry type from Schema using a FeatureReader in FME 2016
chau
Forum|alt.badge.img+3
I am trying to use a FileGDB template I have to look up the geometry type for each feature type inside the template. The template has no features just the feature type definitions including the geometry type.
If I put an inspector on the Schema output port of my FeatureReader I can see the attribute fme_geometry{0} in the Feature Information panel in the FME Data Inspector.
Using an AttributeExposer on either the value fme_geometry, fme_geometry{} or fme_geometry{0} gives me nothing. If I use a ListIndexer on fme_geometry{} or fme_geometry{0} I still come up empty handed.
I can see the geometry type in the FME Data Inspector, how do I get hold of it?
Best answer by danilo_fme
Hi again @chau,
I created here a example to read too a Geodatabase point geometry.
After the transformer FeatureReader you expose the attribute fme_geometry{0} and after you can use the transformer to test the condicional.
In my example I used the TestFilter :
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • April 17, 2018
Hi @chau,
Which Build of FME 2016 are you using?
Thanks,
Danilo
danilo_fme
  • April 17, 2018
Hi again @chau,
Thanks,
Danilo
chau
  • April 18, 2018
danilo_fme wrote:
Hi again @chau,
Thanks,
Danilo
Hi @danilo_fme, your answer is working and my attempts probably already worked. I guess my mistake here was to trust what I see in the Table View in the Data Inspector. I don't see fme_geometry{0} in the Table View but I can use the attribute to route as you propose. If I use the Attribute Manager to rename the fme_geometry{0} to geometry_type I still don't see it in the Table View. I guess it is marked somehow as "not meant to be seen". Thanks for trying what I didn't :)
chau
  • April 18, 2018
danilo_fme wrote:
Hi @chau,
Thanks,
Danilo
Hi @danilo_fme, for reference I am using FME 2016 build 16674 Win64.
