How to get IFC version in FME?
  • July 10, 2023
  • 46 views
Hi there,
I am working on two IFC files i.e. version_4x and version_2x3. At some point, I want to get or write this version in database. I failed to find any transformer to read or get the exact .ifc version.
Is there a way to do that?
Best answer by anuraggj
Well! I managed to do that. I read the .ifc file as text in FME and applied TestFilter which eventually filters the 'Schema' line containing the actual version used. Trimming it out gives the required result.
  • July 10, 2023
