How to FTP a file after using a filecopy writer
Hello,
I have a workbench that uses a tester to copy files into a folder and zip them based on the create date. This works fine however after I have the files in the new zip file I can't seem to figure out a good way to then use a FTP caller to upload the files since you can't do anything after you have used the filewriter.
Looking for ideas of how to upload this zip file to an FTP in the same workbench?
FMEUpload
hkingsbury
Forum|alt.badge.img+56
  • May 1, 2023
instead of the filecopy writer, use a FeatureWriter set to filecopy. Then you have an output port that can trigger your httpcaller
  • May 2, 2023
Thanks for pointing me in the correct direction.
When I run this it throws the warning "File Copy Writer: Skipped 4 features that were missing source datasets"
I think I might be missing a step somewhere I've tried changing some settings in the feature writer parameter's to no avail. Not sure how to include the source dataset.
hkingsbury
  • May 4, 2023
Its possible you might be missing some attributes on the features - see here under examples for some more details
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/filecopy/Feature_Representation.htm#top
  • May 4, 2023
I apologize I'm still new to FME.
Is this what you are referencing? I thought I might need to use an attribute exposer based on another post I saw but I still get the same message about the missing source dataset.
FeatureWriterimage
