How to find Max and Min when you have missing value ?
vimva679
Forum|alt.badge.img+9
Best answer by geomancer
The workspace, for reference.
vimva679
  • June 6, 2023
am using this query but it is returning NULL for minimumimage
Forum|alt.badge.img+49
You can use a NullAttributeMapper to map those missing values to something else (but what that should be is something you need to decide...)
vimva679
  • June 7, 2023
The overall idea is to obtain maximum and minimum value out. If those 6 columns irrespective of they are missing or having some other value or not .
Even if there are more than 2 values it should check the values in each cell and output the maximum and minimum.
I shall highly appreciate if u cld provide me steps in more details considering that am learning FME .
thank you so much
Forum|alt.badge.img+38
  • June 7, 2023
You could do something like this in an InlineQuerier, choosing to coalesce to an appropriate large value to use for min and a small value to use for max depending on your data
geomancer
Forum|alt.badge.img+48
  • June 7, 2023
Building on the idea of @ebygomm​, where you use a predefined value that is guaranteed to be higher than your highest value, it is possible to do this in an AttributeManager (or AttributeCreator) using math operator x?y:z (if-then-else).
It does not look pretty, but something like the formula below works.
@min((@StringLength(@Value(Attr1))==0)?999:@Evaluate(@Value(Attr1)),(@StringLength(@Value(Attr2))==0)?999:@Evaluate(@Value(Attr2)),(@StringLength(@Value(Attr3))==0)?999:@Evaluate(@Value(Attr3)),(@StringLength(@Value(Attr4))==0)?999:@Evaluate(@Value(Attr4)),(@StringLength(@Value(Attr5))==0)?999:@Evaluate(@Value(Attr5)))
A short explanation: If the length of an attribute is zero, use 999, otherwise use the value of the attribute.
 This is only needed for @min, the value of @max is calculated correctly.
vimva679
  • June 7, 2023
Excellent that works so awesome :)
I am highly grateful and thankful @geomancer​ and @ebygomm​ for your quick  response and providing so detailed steps.
vimva679
  • June 8, 2023
Just a quick, if I wish to add Prefix that is constant would that be like
“N” or “S” or “E” or “W” etc
would it like
min((“N” @StringLength(@Value(Attr1))==0)?999:@Evaluate(@Value(Attr1)),…..
max(“N”@….
With each values there are direction associated with it, so after or before finding the max and min I wish to add Prefix of each values such that it’s like eg
N 0’7
w 0.98
S 0 . 55
geomancer
  • June 8, 2023
would it like
max(“N”@….
N 0’7
w 0.98
S 0 . 55
Place the prefix outside of the @min or @max function.
N @max(...
Also make sure you use the Text Editor, not the Arithmatic Editor.
MinMax_hack_2
vimva679
  • June 9, 2023
N @max(...
MinMax_hack_2
Nops its not getting through @geomancer​ image
For MIN
@min((@StringLength(S@Value(TFS))==0)?999:@Evaluate(@Value(TFS)),(N@StringLength(@Value(TFN))==0)?999:@Evaluate(@Value(TFN)),(E@StringLength(@Value(TFE))==0)?999:@Evaluate(@Value(TFE)),(W@StringLength(@Value(TFW))==0)?999:@Evaluate(@Value(TFW)),(D@StringLength(@Value(TFD))==0)?999:@Evaluate(@Value(TFD)),(U@StringLength(@Value(TFU))==0)?999:@Evaluate(@Value(TFU)))
For Max
@max(S@Value(TFS),N@Value(TFN),E@Value(TFE),W@Value(TFW),U@Value(TFU),D@Value(TFD))
vimva679
  • June 9, 2023
N @max(...
MinMax_hack_2
Just a bit more help and understanding this may help
geomancer
  • June 9, 2023
N @max(...
MinMax_hack_2
You put the strings inside the min and max function, that will not work.
The min and max function should only calculate the minimum and maximum value, ignoring the missing values.
@min((@StringLength(@Value(TFS))==0)?999:@Evaluate(@Value(TFS)),(@StringLength(@Value(TFN))==0)?999:@Evaluate(@Value(TFN)),(@StringLength(@Value(TFE))==0)?999:@Evaluate(@Value(TFE)),(@StringLength(@Value(TFW))==0)?999:@Evaluate(@Value(TFW)),(@StringLength(@Value(TFD))==0)?999:@Evaluate(@Value(TFD)),(@StringLength(@Value(TFU))==0)?999:@Evaluate(@Value(TFU)))
@max(@Value(TFS),@Value(TFN),@Value(TFE),@Value(TFW),@Value(TFU),@Value(TFD))
After that you can determine the string like in your last post.
vimva679
  • June 16, 2023
@geomancer​
the workflow and results were not right for me , so had to change the method.
What i am looking now is 1st two(2) minimum values out of each records (row)
vimva679
  • June 16, 2023
like
1st Min 2ndMin
30.00 59.99
44.99 45.00
geomancer
  • June 19, 2023
Sorry to hear the solution was not sufficient.
As it's monday morning, and I am feeling creative, I came up with an unorthodox solution (which has been used before on the forum, I am just borrowing that idea).
Treat the values of your variables as X-coordinates of points along a line, and find the 2 points closest to 0. This assumes you only have positive values. Missing values are allowed, they will simply be skipped.
As you create new geometries, extract and later restore the original geometry.
Minimal_2_values
vimva679
  • June 19, 2023
Minimal_2_values
@geomancer​ this is so brilliant thank you million times and once again, i was worried for ...what if there were 1st two same minimum , would it skip to next or keep the same , BUT here i could see from your example that it does retain same value e.g. 45 value , so its does that smart things 🙂 .
Would it also handle alphanumeric for each value as well ? for example each values have Direction (U, D, N , E, W ,S ) header associated with it . So whatever maybe the 1st two minimum values it also take the default Direction with it .
Also i noticed vertex creator U is missing , is it just typo error or for some reason ? In meantime i shall try to add this into my workbench and test results / tnx once again
1st Min
30
45
12
2nd Min
60
45
33.33
1st Min_Dir
E
W
E
2nd Min_Dir
S
N(*)
N
FINAL_expected_Output
E 30 S
W 45 N
E 12 N
*to be careful here is even though 1st min and 2nd min is same its should extract its respective Direction and not the same i.e. 45 45 W W OR N N as this would be incorrect
geomancer
  • June 19, 2023
Hi @vimva679​ ,
Sure, just add an attribute for the Direction, add it to the list in the Neighborfinder, and get the value in the AttributeManager. I also added D for completeness.
Minimal_2_values_v2In all modesty, this is not my brilliance. I just reused a smart idea from other users. Learning from the ideas of others is one of the great things about this community. Which is also why I want to give back by using others.
geomancer
  • June 19, 2023
vimva679
  • June 19, 2023
Perfect @ its exactly right now this time 🙏 thank you @geomancer​
geomancer
  • June 19, 2023
You're welcome :)
wcnoname
Observer
  • Observer
  • July 10, 2024
Hi @geomancer !
Just found your solution for my problem. I tried to adapt your formula to my attributes but somehow it returns as min value 0
Im testing the adress fields {1-5} and the min field ist the one i calculate
The formula i am using is the following:
@min((@StringLength(@Value(Adresse_{1}))==0)?999:@Evaluate(@Value(Adresse_{1})),(@StringLength(@Value(Adresse_{2}))==0)?999:@Evaluate(@Value(Adresse_{2})),(@StringLength(@Value(Adresse_{3}))==0)?999:@Evaluate(@Value(Adresse_{3})),(@StringLength(@Value(Adresse_{4}))==0)?999:@Evaluate(@Value(Adresse_{4})),(@StringLength(@Value(Adresse_{5}))==0)?999:@Evaluate(@Value(Adresse_{5})))
Do you have any idea why the result is 0 and not 16 ?
geomancer
  • July 10, 2024
I am always happy to see re-use of old solutions :)
But this is very strange...
When I create a test with your values,and enter your formula, it gives 16 as the minimum value, as expected. So I can’t reproduce the result 0.
wcnoname
Observer
  • Observer
  • July 10, 2024
You are right! I manually rebuilt the dataset and the result was 16.
I’m not shure wheter it has to do with the datatype. I tried with number and char, both worked.
The dataset i am working with was derived from a pdf an processed with different transformers. The datatype of the ‘adresse{}’-attributes is varchar. Maybe it is because of this. I have no idea…
wcnoname
Observer
  • Observer
  • July 10, 2024
Somehow the stringlength of the missing value delivered “4”. Therefore it didn’t work.
I included a conditional value: if missing value set value 9999 in the attributemanager and it worked.
thanks again for the prior solution! Helped a lot!
