How to FILTER cell of COLUMN in excel based on COLOUR in FME ?
vimva679
Forum|alt.badge.img+9
I have got an excel sheet and there are some cells with just colour and i don’t wish to include them for analysis purpose / output .
Without any edits in Excel sheet (eg. add some kind of numeric or standard text for colour cell etc.) i wish to remove or exclude. I also don’t wish to depend on any other column or cell value to filter rows with ORANGE colour cell
I WANT to remove / exclude entire ROW that has yellow colour in cell in Column NCR Ref
Best answer by danilo_fme
Hi @vimva679
Attached the Workspace template developd in FME 2024 version.
danilo_fme
Forum|alt.badge.img+47
  • May 30, 2024
Hi @vimva679
I suggest you enable the format attribute from Source:
Read formating (.formating)
After you can configure the transformer Tester:
Thanks in Advance,
Danilo
vimva679
  • May 30, 2024
Thank Danilo @danilo_fme for your quick response, i tried that for different column but look not getting it right
danilo_fme
  • May 30, 2024
Hi, I did understand the combination now. Please, wait some seconds.
danilo_fme
  • May 30, 2024
Please - could you share me your input data?
vimva679
  • May 30, 2024
Hello @danilo_fme please find the sample file attached. The text is inconsistent and it changes from file to file. So only common thing is colour of the CELL
danilo_fme
  • May 30, 2024
Thanks for your data. In a few minutes - you will have the results :)
danilo_fme
  • May 30, 2024
Hi @vimva679
vimva679
  • May 30, 2024
Excellent , it works perfectly , thank you so much for great learning. Highly appreciate and obliged with your quick response. I tried it 2022.2 FME version and its works as well :) .
danilo_fme
  • May 30, 2024
Awesome. I’m happy to help you!
vimalvaghani
Participant
So @danilo_fme please on another know-how does it mean if I want to find or identify if any STRIKED records in Excel sheet,then I type “Strike” in (Right Value )and it would pass entire rows / cell in rows that are striked off i.e. Strike and Not Stiked rows could as well be seperated likewise separating records based on CELL colour?
Also where can I or which documents on FME could I find such settings or commands please /Br
jkr_wrk
Forum|alt.badge.img+29
  • May 30, 2024
vimva679
  • May 30, 2024
GOT it right now : STRIKEOUT
