How to filter based on several attributes instead of one attribute?
joy
Forum|alt.badge.img+15
I am currently importing a dgn file into FME and I am trying to filter the cells based on the following attributes igds_cell_name and igds_cell_insertion_x/y/z . With the AttributeFilter one is able to filter based on one attribute, however I would thus like to filter based on the above mentioned 4 attributes , so I can aggregate afterwards the cells that have the same value for the above mentioned attributes. Does anyone know how I might be able to achieve that. I wouldn't want to make use of a TestFilter, since with a TestFilter you have to write manually out all the possible values with AND clauses. That would be too much work for me.
Best answer by dustin
I would use a StringConcatenator to combine the values from the 4 attributes into one attribute value. Then aggregate based on the new concatenated value.
dustin
Forum|alt.badge.img+31
  • April 13, 2022
joy
  • April 13, 2022
@dustin​ This works like a gem, thanks for this clever idea!
