How to expose KML tag with XQuery
I am trying to extract the KML tags for the KML below (structure) using the XQueryxtractor transformer
declare default element namespace "http://www.w3.org/1999/xhtml";
for $x in /html/body/table/tr/td
return fme:set-attribute($x/td[1]/text(),$x/td[2]/text())
the result is coming out empty. Any suggestions ?
kml_description (encoded: UTF-16LE): <html xmlns:fo="http://www.w3.org/1999/XSL/Format">
<body> <table border="0" width="370" cellpadding="0" cellspacing="0"> <tr bgcolor="ffffff"> <th width="370" align="left"></th> <th width="370" align="left"></th> </tr> <tr> <td bgcolor="#ffffff">Manhole ID</td> <td>50283792</td> </tr> <tr> <td bgcolor="#ffffff">Life Cycle</td> <td>In-Service</td> </tr> <tr> <td bgcolor="#ffffff">Manhole Size</td> <td></td> </tr> <tr> <td bgcolor="#ffffff">Installation Date</td> <td>1/1/1111</td> </tr> <tr> <td bgcolor="#ffffff">Drawing Number</td> <td>MHE2-009-552</td> </tr> <tr> <td bgcolor="#ffffff">Grid</td> <td>4030420</td> </tr> </table><br></body> </html>
itay
Forum|alt.badge.img+17
  • March 22, 2018
Looks like html to me so why not use the HTMLExtractor or simply read it as XML and use the XML reader to extract the data?
  • March 22, 2018
  • Firstly make sure that the default namespace declaration in your expression is correct. I don't know if it's correct, since the XML fragment you have posted is incomplete (cannot see the root html tag and default namespace declaration),
  • In your expression, the variable $x indicates "td" elements specified by the XPath "/html/body/table/tr/td", and you intend to retrieve values of its child elements called "td". Naturally the expression returns the empty, since the "td" element doesn't have a child called "td". I think $x should be "tr" element here.
  • March 22, 2018
I noticed that this <br> element in your HTML fragment is not closed.
</table><br></body>
That is, the HTML fragment is not a valid XML, so the XMLXQueryExtractor cannot parse it. You will have to modify it to a valid XML, or consider adopting other approach. e.g. HTMLExtractor.
This is the updated version of the xQuery and is coming empty also.
this data is comming from an attribute call kml_description (encoded: UTF-16LE)
for $x in /html/body/table/tr/td/table/tr
  • March 22, 2018
The HTML fragment you have posted is incomplete (the starting html tag is missing). Also, as I mentioned in the previous comment, the <br> element is not closed.
The XMLXQueryExtractor cannot parse it anyway.
If you modified the HTML fragment to a valid XML fragment and if the default namespace was correct, this expression could work as expected.
where 1 lt fn:count($x/td)
The HTMLExtractor is working, but i am going to try your suggestion.
Thank you
Is not working. The _result field is empty.
  • March 22, 2018
It's fine. The expression sets new attributes internally, doesn't return any value.
Connect a Logger and/or Inspector, and see the result on the Translation Log or the Feature Information window in FME Data Inspector. If the expression works fine, you can see new attributes - "Manhole ID", "Life Cycle", and so on.
