How to eliminate empty spaces in address field?
  • February 18, 2023
  • 18 views
vxn43
Forum|alt.badge.img+18
If I have addresses in an address field formatted for example:
1234 Elm St
...and I want to remove all spaces to change the field value to look like this:
1234ElmSt
What Transformer and Parameter would I use?
Best answer by danilo_fme
Hi @timh​
There is another sugestion for your case. Is the custom transformer StringCleaner:
StringCleaner
Thanks in Advance,
Danilo
tomfriedl
Forum|alt.badge.img+13
  • February 18, 2023
You can use StringReplacer​. Substitude space through nothing.
danilo_fme
Forum|alt.badge.img+45
  • February 20, 2023
Hi @timh​
StringCleaner
Thanks in Advance,
Danilo
