How to downsample resolution of raster data
limo
Forum|alt.badge.img+8
we have raster data (orthophotos) with a ground resolution of 8cm.
Is there a possibility to downsample the ground resolution to 20cm?
Based on some limitations we sometimes have to use 20cm ground resolution.
Does anyone know if something like this is possible with the fme?
  • January 11, 2023
thijsknapen
Forum|alt.badge.img+10
  • January 11, 2023
Hi @limo​ ,
I believe the RasterResampler transformer can be used for exactly this usecase;
"Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values."
See also its documentation page for more info and a visual illustration of how the transformer works.
limo
  • January 11, 2023
I thought only number of columns and rows are possible.
So you are right I can set cell size x and y. Are the values in meter?
So if I have an orthophoto with 8cm ground resolution and I set 0.2 for x and y value then I get the orthophoto with 20cm ground resolution. This is exactly what we need.
  • January 11, 2023
As mentioned in the documentation, the values are in ground units. Meaning that if the coordinate system of your raster is in meters, then the values are also interpreted as meters. However, if your raster coordinate system is in e.g. Lat/Long, then the values will be interpreted as being in decimal degrees.
limo
  • January 11, 2023
ok I understand ... thanks @david_r​
