How to develop a linked custom transformer (the right way!)
  • January 4, 2021
  • 120 views
Hello,
this topic is based on this initial post from me:
https://community.safe.com/s/question/0D54Q000080hM3SSAU/what-are-the-fme-best-practices-for-modularization?t=1609774258752
However, the question is now a bit different. Therefore, I will open up a new topic.
Goal: I would like to develop a linked custom transformer
Issue: If the custom transformer has some sort of complexity, I have problems debugging it, since things like “feature caching run” is not available there.
Used FME Desktop Version: 2020.1.3.0 (Build 20632)
I tried 3 possible solutions, but I have some issues with all of them. Maybe you can help me out finding the “right way” to do it.
Possible solution 1: Convert the linked custom transformer into an embedded one, develop inside the embedded custom transformer and then export it back into a linked custom transformer.
Possible solution 2: Copy the content of the linked custom transformer into a new workspace, develop inside this new workspace and copy it after the development back into a new version of the linked custom transformer.
Possible solution 3: Do not use linked custom transformers at all, but use exported embedded custom transformers.
Issue with solution 1: The different versions are lost. If I had a linked custom transformer with versions up to i.e. 5 and I convert it into an embedded custom transformer and after the development exporting it back into a linked custom transformer, the version will start from 1 again (instead of beeing i.e. 6).
Issue with solution 2 (which I am using right now): It’s a bit inconvenient. In addition, the whole copy&paste-process doesn’t feel right.
Issue with solution 3: I cannot handle the version-upgrade inside the FME-scripts, which are using the custom transformers, in a proper way (via upgradable transformers individually for each custom transformer)
Thanks in advance and best greetings
Florian
  • January 14, 2021
Hi Florian! Good (and unfortunate, obviously) to hear that me and my colleague aren't alone in this situation, since we've identified pretty much the same alternatives. We're also using #2 now, which works fine but isn't really desirable in the end. For connections, we've managed to experiment a bit with using a network-drive to have a shared "pool" of connections. Which is great if the VPN or connection is solid, but causes crashes if it loses connection mid-run - the kind of "FME.exe just crashes and goes away"-crashes, that means something _really_ went wrong.
I am not sure if it's possible to have a shared folder (also accessible under FME Options -> Default Paths) in which the installed transformers are stored. I am uncertain if "installing" actually does anything, or just puts the transformer in the correct location. http://docs.safe.com/fme/2020.0/html/FME_Desktop_Documentation/FME_Workbench/Workbench/custom_transformer_install.htm seems to indicate this could work. Do you have a good situation in which to try this, or should I give it a go?
