Basically, can anyone tell me the format of this value. For example if I want the reference scale to be 1:800?
How to define the Annotation reference scale on ESRI file GeoDB's
Best answer by trentatsafe
Hello @andypcatbcc
If you take a look at the following link: http://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_ReadersWriters/geodatabase/Configuration_Parameters.htm
There is a section about 3/4 down the webpage, that lists the 'GEODB_ANNO_REFERENCE_SCALE'. I believe this is the format attribute you are looking for, in order to set the Annotation's reference scale.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
