How to create multiple features?
  • April 21, 2017
  • 8 replies
  • 240 views
Dear FME-Users,
I’d like to create multiple features (e.g. shapefiles) from multiple input rasters. For instance: I’ve 3 input raster and I’d like to have 3 features as output.
But it does not work, I get just 1 output-feature as result.
You’ll find my FME-workflow in the attachment.
Thank you very much and best regards. :)
Konrad
  • April 21, 2017
You need to do a fanout on your writer based on an attribute unique to each output file. You can e.g. use a Counter if you just need an incrementing filename.
Example:
  • April 21, 2017
Example:
It seems that just the name of input files are differnt. I really need to do a fanout? I've 72 files.
  • April 21, 2017
You can try fanning out based on the "fme_feature_type" attribute. You may have to expose it on the reader first, if it's not visible in the workspace.
  • April 21, 2017
I’ve tried „fme_basename“, now it works. :) Thank you very much @david_r.
itay
Forum|alt.badge.img+19
  • April 21, 2017
In that case use the fme_basename (raster file name), just make sure to expose it in the reader.
itay
  • April 21, 2017
itay
  • April 21, 2017
glad I also could help.
  • April 25, 2017
Yes @itay thank you very much too. :)
