How to create an Userparamter with picture depht/bit depht choice?
  • Dec 12, 2020 6:16 PM UTC
  • 31 views
Hello all, I want to create an user parameter to let the workspace user choose between three different picture depht/bit depht: (gray 8, palette 8 and RGB24). I used the RasterInterpretationCoercer, but how do I connect it right with an user parameter? My Result is an userparameter prompt with an list of all possible choices of the RasterInterpretationCoercer (below in the attached picture) But I want just the 3 different possibilities
Thank you very much.
Screenshot 2020-12-12 191454
hkingsbury
Forum|alt.badge.img+73
  • Dec 13, 2020 7:12 PM UTC
If you right click on the user parameter and select Edit DefinitionScreenshot 2020-12-14 080352
Then click the three dots next to ConfigurationScreenshot 2020-12-14 080411and that will bring up a list of where you can edit your options
Screenshot 2020-12-14 080421
