How to create a list of integers between two numeric values for individual features?
  • July 13, 2023
  • 116 views
achambers
I have a land records data set that has a beginning page and an ending page. Both are numeric values. I would like to create a list of all possible page numbers (integers) between the beginning and ending page number. Is there an easy way to accomplish this?
caracadrian
Forum|alt.badge.img+23
  • July 14, 2023
You can easily create clones and calculate a "current page number" for each feature in the interval.
Use an AttributeManager to calculate a page_interval attribute with a calculated value @Value(page_end)-@Value(page_start)+1 (the +1 is needed to get the correct number of page 25-1=24 but you have 25 pages so +1).
Send the results to a Cloner with number of copies value from the page_interval attribute.
Send that to a second AttributeManager where you create a page_number attribute with the value set as @Value(page_start)+@Value(_copynum).
If your first page always has a value of 0 (zero) just use the last page attribute in the Cloner without any other calculations.
clone by page
