How to create a center point from multiple features grouped by an attribute
  • Apr 28, 2023 2:01 PM UTC
  • 331 views
ronmak
Forum|alt.badge.img+5
I have a large data set that has been read from multiple autocad drawing files. At the current stage each feature has an attribute "project_num". There are many feautres (usually lines) for each project_num. I would like to get this down to a single "centroid coordinate" (preferably center of gravity) for all of the lines from each project_num.
CentrePointReplacer will generate a single point for every feature.
I tried FeatureMerger but am having problems. Both the Supplier and Requestor are set to "project_num". I have set the Feature Merge Type to geometry and checked "process Duplicate Suppliers" (build polygons) but get the same number of merged features as the input. If I use the "group processing" option, I still get the same number of merged features.
My current workaround is to use the DuplicateFilter before sending it to CenterPointReplacer. I have also tried creating a point cloud from all the resulting CenterPoints and then running CenterPointReplacer on the resulting point cloud.
I'm thinking there is a better way to do this!
dustin
Forum|alt.badge.img+36
  • Apr 28, 2023 2:13 PM UTC
You should be able to use an Aggregator with Group By set to 'project_num', then feed those aggregates into the CenterPointReplacer.
ronmak
  • Apr 28, 2023 3:11 PM UTC
Thanks.
This looks promising but the CenterPointReplacer doesn't seem to like aggregate geometry. It rejects the first one and then terminates with an error.
I notice that CenterPointReplacer now only has two options for modes: "Centerline" or "Straight Skeleton". Both result in the same error.
dustin
  • Apr 28, 2023 3:21 PM UTC
Thanks.
Instead of the Aggregator, you might consider using the HullAccumulator with Group By set to the 'project_num'. This should create an area feature around the input features, which you can certainly use in the CenterPointReplacer.
