I am using FME Workbench 2018.1.0.1 in Windows 10. I am inputting a kmz file. The only parameter I am reading from it is PLACEMARK because I see no reason to read the others. I need to copy format attributes kml_name and kml_description to NAME and CAPACITY, respectively. I don't see in the AttributeCopier transformer where I can do this. Its Import Wizard does not seem to be made to do this
How to copy FME format attributes
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
