How to convert CSV (Longtitude & Latitude) to point (shapefile) and after that filter by polygon to select and export point which intersect with polygon?
  • Jul 24, 2021 11:46 AM UTC
  • 359 views
khaphan
I have a CSV file with Longtitude and Latitude fields (more than 10.000 records) and I want to convert these to point (shapefile). After that I want continue use a polygon to select which points intersect with it? I tried to use VertexCreator and SpatialFilter or PointOnAreaOverlayer but it didn't work like my expect. So who can help me to solve this problem. Thank you so much! CSV2PointCSV2Point_3CSV2Point_2CSV2Point_1
jkr_wrk
Forum|alt.badge.img+37
  • Jul 24, 2021 12:27 PM UTC
If you connect an inspector to the Reprojector and one to the VertexCreator. Do both geometries show up on the same location?
khaphan
  • Jul 24, 2021 12:33 PM UTC
Yes, cause CSV has longitude and Latitude that coordinate System is LL84. So I have to reprojector Polygon to same LL84 project.
khaphan
  • Jul 24, 2021 1:00 PM UTC
After SpatialFilter step, the data be written to POP_Elderly60.shp but it have error "SHAPEFILE writer: Failed to delete the following files: 'mapping_log.ffs'. Please ensure that the files are not in use and that you have sufficient privileges to delete them.".
