How to convert CAD texts to points in FME?
  • September 3, 2014
  • 8 replies
  • 212 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out how to convert the CAD texts to points in the FME. In the ArcGIS, the CAD texts are recognized as “annotation” and thus can be selected and converted to points whose attribute table carries the value of the text.
How this can be accomplished in FME?
The dwg file:
http://www.mediafire.com/download/xhrc6kchbacx0s0/Parcels.dwg
Thank you
Best
Jamal
  • September 4, 2014
Hi Jamal,
You can use the GeometryCoercer (Geometry Type: fme_point) to transform Text geometries into Point geometries. Resulting point feature retains text string as attribute called "fme_text_string" or "autocad_text_string", so you can expose it with the AttributeExposer, if necessary.
Takashi
jamal
  • September 4, 2014
It appears that the FME doesn’t detect the CAD text. Am I correct?
  • September 4, 2014
Two possible cases.
1) The source dataset doesn't contain the Text features.
2) You've filtered out feature types other than Line feature by setting"Feature Type to Read" parameter of the reader.
jamal
  • September 4, 2014
Many thanks Takashi for the help,
Now it appears to work fine. I could catch the texts of the CAD.
  • September 5, 2014
Good to hear you've accomplished the purpose.
Some tips for brushing up the workspace:
1) In some cases, TestFilter could be more efficient than using multiple Testers in parallel. And also, if there always are just 2 feature types (i.e. Text and Line), just one GeometryFilter might filter them properly, instead of 2 Testers and 2 GeometryFilters.
2) Text features will be treated as same as point features representing text locations when comparing spatial relationships with other features.
3) The AreaBuilder accepts aggregate (multi-part) line features and duplicated lines.
jamal
  • September 5, 2014
My approach in converting parcels from CAD to GIS is
1. To extract the parcel layer (with “tester” command)
2. To explode all the content of the layer (the parcel layer could originally contain lines, polygons, arcs and other data type, i.e. this layer might not be clean: with which tool?)
3. To remove the duplicates in the layer (with “matcher” tool)
4. To convert all the contents of this layer into lines (which tool can do this?)
5. To convert lines to polygon ( with “areabuilder” tool)
6. Then the texts are migrated from text layer to polygons (with “spatialfilter” tool)
Is this the best practice?
  • September 6, 2014
There are always several ways to do same thing, so I cannot say what is the best practice. Just can provide other options.
If there could be several layers other than Parcels_Numbers and Parcels_Polygons in the actual source data, I would add reader feature types for Parcels_Numbers and Parcels_Polygons as Individual Feature Types, rather than adding a Single Merged Feature Type (_ALL_). Then, the Testers will not be essential.
If the Parcels_Numbers layer can contain features with geometries other than text type, the GeometryFilter_2 is necessary to filter out invalid geometries. But the SpatialFilter treats text geometries as same as point geometries representing text locations when comparing spatial relationships, so the GeometryCoercer_2 and the GeometryFilter_3 are not essential.
If the Parcels_Polygons layer can contain features with different geometry types e.g. line, polygon, arc, ellipse etc., the GeometryFilter may be necessary to filter out unpreferable geometries. But the Intersector can intersect lines, arcs, polygons, ellipses, and aggregate features, and also the AreaBuilder accepts duplicated features. So the Deaggregator, the Matcher, and the GeometryCoercer may not be essential.
Of course all should be decided depending on the actual data conditions and the purpose of the workspace. Therefore, only the person who can know all the conditions - i.e. only you can decide the final design.
Good luck!
jamal
  • September 6, 2014
Thank you very much Takashi for the very useful comment.
Best
Jamal
