How to convert a 3d mesh to raster?
  • Sep 19, 2023 1:56 PM UTC
  • 5 replies
  • 365 views
stezi
I want to generate a textured plane top-down projection from a mesh.
Like a raster equivalent for the SurfaceFootprintReplacer, which would derive a footprint polygon.
Is there a transformer for that use case?
j.botterill
Forum|alt.badge.img+69
  • Sep 19, 2023 3:18 PM UTC
Hi Stezi, perhaps RasterExtentsCoercer - Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster.
Otherwise use RasterInterpretationCoercer if you need alter the interpretation type of rasters, including all bands, and converts cell values.
Something like RasterExtractor follower by RasterReplacer like this rasterextractreplace_polygonGeometryCoercer to polygon
stezi
  • Sep 20, 2023 5:59 AM UTC
As the input is a mesh, unfortunately those raster transformers won't work.
stezi
  • Sep 20, 2023 6:18 AM UTC
There is NumericRasterizer but it generates the raster based on z-values. However, I want to create the raster from texture color values.
itsmatt
Forum|alt.badge.img+48
  • Sep 20, 2023 8:56 AM UTC
Here's a similar question from a couple of years ago
https://community.safe.com/s/question/0D54Q00008udxjCSAQ/top-down-georeferenced-image-from-photomesh
The solution was to first convert to a pointcloud
stezi
  • Sep 20, 2023 11:21 AM UTC
Great solution (PointCloudCombiner > ImageRasterizer)! :)
