how to connect two different layers data of .dwg file? (point and line)
  • Nov 30, 2022 11:04 AM UTC
  • 8 replies
  • 161 views
saravanakumar
Hello all,
I am trying to merge two different layer data from DWG file. In that one layer is line geometry and another layer is point (text) . Here I wish to connect text to nearer line geometry but I tried different transformers but I could not !
FYI - I tried spatialfilter, Neighbourfinder
imageThank you for advance!
Forum|alt.badge.img+63
The NeighborFinder should be the one for this. Can you share what you've tried with that?
saravanakumar
  • Nov 30, 2022 11:34 AM UTC
this is the workbench I created with neighbourfinder imagewhile running this I am facing a error like below image
imagethe properties of neighbourfinder.
imagethank you for your response !
I think the NeighborFinder settings are good, but there may be something with the TextPropertyExtractor. Sadly it doesn't look like there's a <rejected> feature being created.
Can you try taking the TextPropertyExtractor out and see if that makes a difference? That would help to pinpoint the source of your errors.
saravanakumar
  • Nov 30, 2022 12:53 PM UTC
hi ... yeah It is moving without error but I want to associate text values ....
without TextPropertyExtractor how can I get the values from that layer ?
Since you've ticked the "Merge Attributes" option in the NeighborFinder, the Matched Base output should have received the attributes from the (matching) candidates. Can you check that?
saravanakumar
  • Nov 30, 2022 1:14 PM UTC
Actually If I not use the TextPropertyExtractor I could not able to fetch text details in that layer!
BM_ROADNAME without TextPropertyExtractor
imageAfter the TextPropertyExtractor usage
imageactually I need the text attribute to join with nearer line geometry !
Right, but there is something in the TextPropertyExtractor that makes the NeighborFinder throw up. Can you try an AttributeExposer instead of the TextPropertyExtractor? If you expose the attribute fme_text_string it should have the same values, maybe that works.
saravanakumar
  • Nov 30, 2022 1:30 PM UTC
imagethanks @Hans van der Maarel​  It is worked !🙂
Regards,
saravanakumar
