How to compare two columns. If it is matched, change to the new value
  • Sep 15, 2023 5:49 AM UTC
  • 108 views
Dear Sir / Madam,
So I have two excel tables. Mother name.xlsx is the original data and waterbody.xlsx is another table.
So I would like to compare two excels. If both excels' column "ModelName" are matched. The mother name excel's model name column should change to newmodelname column. If not, just keep the original modelname.
I try to use tester transformer but I am not sure why nothing can be matched.
I hope someone can give me a hand.
The output that I want is in the Output.xlsx
Thank you very much.
nielsgerrits
Forum|alt.badge.img+67
Before you can compare two values in one row, you must merge them. One way to do this is to use a FeatureMerger. Is this the pointer you needed?
