How to clip multiple polylines using overlapping polygons without losing or gaining line segments inside polygon
  • November 30, 2019
  • 71 views
I have a workspace that has multiple line segments and several overlapping polygons, I would like to clip the line segments to the polygons without gaining or losing line segments in the polygon, I have tried cloning and also geometry replacement and spatial relator but I always end up with merged line segments inside the polygons after clipping. Some of the resulting lines that are clipped span the entire length of the polygon.
Here is what I am currently attempting, I am using method from this answer in the forum. I have the parameters set the same as in the post made by takashi
https://knowledge.safe.com/questions/90178/clip-line-for-each-overlapping-polygon.html
Forum|alt.badge.img+40
  • November 30, 2019
I would use a spatial relator to build a list on each line of the polygons it intersects. Explode the list, then use the polygon id as a group by in a clipper
  • November 30, 2019
autocad_od2none.fmwt Here is the workspace I use to test your method, thank you very much.
