How to change from user attribute based relationship class to Global 'ID based relationship class and not losing the data .
  • Feb 21, 2019 10:23 PM UTC
  • 111 views
bhanu_v
I have a feature classes and table that have relationship class based on a user attribute field as PK-FK.(1-M) simple .This feature class also has Global Id's.
we are moving towards collecting this data now in Collector and as best practice want to move to a relationship class based on Global'Id.
I understand that I have to create a new relationship class as you cannot edit an existing one
but how do I do it without losing the data .
I would appreciate insights from anyone who attempted to do this
@adi Did you try the Add GlobalID's tool in the Esri stack? You can accomplish this in FME but you'd have to build the workspace for each relationship as per the example described in "Introduction to Working with Geodatabase Relationship Classes"
bhanu_v
  • Feb 22, 2019 4:41 PM UTC
Hello @MarkAtSafe,
Thank you for your reply
The feature class has global Id's populated in them but the relationship is not based on this global id ,
The actual data Im working on is that
I have a poles featureclass with PoleID (user generated Alphanumerc string)
with related table of signs table has PoleID field where the PoleID is Foreign Key in this and its (1 to many) one pole has multiple signs attached to the pole.
Now I want to change the relationship table to have relationship to be on Global'id
how to change this without breaking the data.
