How to change color of lines and write it in Esri shape file
  • Dec 28, 2022 6:35 AM UTC
  • 284 views
gogopotter90
Forum|alt.badge.img+14
Hello ,
I would like to have fixed color of lines and write it into Esri shape file.
i have used feature color setter or DGN styler but it does not work .
when I read the shapefile again , I have found it has random color .
Any help please
FME 2021
Best answer by caracadrian
ESRI SHP format doesn't store styling information. That is the normal behavior of a GIS software.
As a workaround I create a color attribute (RGB/HEX depending on software) and use the attribute as a color value when styling. You can use ColorCalculator custom transformer.
caracadrian
Forum|alt.badge.img+23
  • Dec 28, 2022 8:39 AM UTC
gogopotter90
  • Dec 28, 2022 2:02 PM UTC
K, I got u .thanks
