I have a polyline that I have reprojected in a new coordinate system. Before it was lines and arcs but after the transformation the arcs are many little lines. Is it possible to transform back this little lines in arcs?
Thanks
Thanks
Best answer by takashi
If you have written the translation result into a certain format file to check the result, there could be a limitation in the format, rather than the reprojection itself.
Try connecting an Inspector to the ReframeReprojector so that you can check the result with FME Data Inspector.
No account yet? Create an account
