How to capitalize first letter in string and leave the rest of string as is?
  • Mar 7, 2018 7:31 AM UTC
  • 7 replies
  • 928 views
Hello,
I'm looking for a way to capitalize the first letter of a string but leave the rest of the string untouched.
I have tried the StringCaseChanger, but that didn't seem to yield the result I was looking for. Have Want de Gouden Draak De Gouden Draak het Rijksmuseum Het Rijksmuseum paleis op de Dam Paleis op de Dam
Thanks,
Ed
  • Mar 7, 2018 7:42 AM UTC
Hi @edhere, split the input string into the first character and the rest part, change the first character to uppercase, then concatenate them. The SubstringExtractor, the StringCaseChanger, and the StringConcatenator might help you.
Alternatively this string expression could also work as well.
@UpperCase(@Substring(@Value(_text),0,1))@Substring(@Value(_text),1)
fmelizard
Forum|alt.badge.img+22
  • Mar 7, 2018 8:20 AM UTC
Hi @edhere Or with a TclCaller:
return [string toupper [FME_GetAttribute _text] 0 0]
  • Mar 7, 2018 8:51 AM UTC
Hi guys,
Thanks for the comments, I couldn't get above solutions to work so I used below. Seems to do the trick as well.
But a shorter version would be nice of course!
@takashi - Where would I put:
In an AttributeManager?
@DanAtSafe - I'm not familiar with the TclCaller, can you perhaps show me how the transformer should look with the code?
  • Mar 7, 2018 9:14 AM UTC
Scripting. I tried other languages, but probably the Tcl expression could be most concise.
JavaScript (JavaScriptCaller)
var t = fme_get_attribute('_text');
fme_set_attribute('_result', t.replace(/^./, t.charAt(0).toUpperCase()));
XQuery (XMLXQueryExtractor)
let $t := fme:get-attribute("_text")
return fn:replace($t, '^.', fn:upper-case(fn:substring($t,1,1)))
denizturan1985
Participant
Hi guys,
Hi Ed, I think it should be like:
  • Mar 7, 2018 9:20 AM UTC
Hi guys,
The string expression is just an alternative. You can set the expression to the Attribute Value column in an AttributeManager or AttributeCreator.
However, if you got your desired result from those transformers, no need to use the expression.
  • Mar 7, 2018 9:26 AM UTC
Hi guys,
If you are interested in Tcl, try this.
