how to cancel point that intersected between five paths and consider the paths is not connected
  • Mar 27, 2020 1:18 PM UTC
  • 84 views
gogopotter90
Forum|alt.badge.img+14
i have 5 pathes of lines and they intersected in one point and each path has 4 connected lines and each lines has his own id .
when i use network topology uilder by id ,i find it considers all lines in all paths as connected has the same value of network id
i want to work on each 5 paths but as not connected in one point ,how could i do that .
i mean ,as first path that has 4 connected lines and each lines in this path connected till the point that intersected with another paths
i want to consider 4 lines in each path as conneced but not connects with another path
i do not want to consider every path that includes lines as connected to other paths .i want to make each path as seperated ,how could i do that.Thanks
Best answer by gio
@gogopotter
hi,you can use edge output as it has a to and form node. You can merge on node_id.
gio
Forum|alt.badge.img+15
  • Mar 27, 2020 4:07 PM UTC
@gogopotter90
If you have pushed your lines trough a TopologyBuilder you will get a list called node_angle{}.
Use listelementcounter on this list.
result 1 is endnode (i believe this is what you are looking for), >1 is ok node and rest is wrong
Iuse this test to manaualy correct networks during networkbuilding etc...(in fact i was just doing it again)
Greetz!
gio
  • Mar 27, 2020 4:19 PM UTC
@gogopotter90
to be correct >2 is correct.
As =2 can be a "in-line" node which is not correct for a network. Can indicate a drawing errro for instance.
As are 2 endnodes close together; likely drawing error.
etc.
gio
  • Mar 28, 2020 12:19 PM UTC
@gogopotter
