how to calulate the digits in column of x and y utm coordinates before the decimal point
  • Nov 16, 2019 9:36 AM UTC
  • 5 replies
  • 70 views
mehar
Forum|alt.badge.img+3
i need to extract the coordinate which are wrong and does not make sense like easting in utm should be 6 digits .because i have some coordinates in x column for example (easting = 7 digits 3628623.384 ) which is wrong it should be 6 digits. is there any way i can calculate the digits in coodinates column before the decimal point
  • Nov 16, 2019 10:47 AM UTC
Use a SubstringExtractor to pull out the digits before the decimal point:
Start index: 0
End index: @FindString(@Value(x-coord),.)-1
x-coord is your x attribute, . is what you're looking for and -1 to get the position one step to the left of the decimal point.
Then use a Tester to check that the resulting string isn't too long:
@Evaluate(@StringLength(@Value(_substring))) < 7
_substring is the string you just pulled out with the SubstringExtractor.
  • Nov 16, 2019 10:57 AM UTC
You can use the Tester to test if the value is less than 1000000 (i.e. the minimum value of 7 digits).
  • Nov 16, 2019 11:20 AM UTC
Doh. Sometimes the answer is just too obvious. :-) In my defense, I'm busy at work with the same maneuver but with character strings, so that's where my head is at the moment.
mehar
  • Nov 17, 2019 12:21 PM UTC
thanks takashi
mehar
  • Nov 17, 2019 12:22 PM UTC
Start index: 0
thanks danullen really appreciated
