How to build polygons from lines?
  • December 1, 2015
  • 818 views
tono
Forum|alt.badge.img+13
Hello,
I am trying to build some polygons from lines that match in nodes and are already closed.
As I try with AreaBuilder transformer i get some polygons, but in that ones that a line shares the boundary of two expected polygons only one polygon is created. Is there anyway to build polygons from shared lines?
Example: In the image you can see how two expected polygons were not drawn.
Thanks in advance!
jpvo
  • December 1, 2015
Hi tono,
I can see some reasons why you areas don't build.
  1. Your lines are not topologically connected. you can use the Snapping parameter to specify a tolerance
  2. your lines are not properly split at intersections. You can use an intersector prior to the Area builder
  3. Make sure you are creating donuts
FME can build polygons from shared lines, good luck.
.JP
fmelizard
Forum|alt.badge.img+22
