How to automate parcel numbering
  • Mar 12, 2013 2:53 AM UTC
  • 68 views
Kindly i need your help , i have a tool in map info that make auto numbering sequentially by clicking in feature
when i press on the feature the value in the record will increase or decrease by a value which i decide, i have to do it manually.
Is it FME capable to do same thing like mapinfo but in automated process.
Any advice.
Thank You
sigtill
Forum|alt.badge.img+25
  • Mar 12, 2013 5:54 AM UTC
If you run all features through the Counter everyone will get their own number (starting from 0 by default, or another value if you prefer). Not sure what you mean by "press on the feature" related to FME - however you can ofcourse increase or decrease the Counter-value if you want to, for instance based on another custom value.
  • Mar 12, 2013 8:16 AM UTC
if you need to increase or decrease an existing attribute value, take a look at the ExpressionEvaluator.
David
davideagle
Forum|alt.badge.img+21
  • Mar 12, 2013 5:19 PM UTC
You might also find the ModuloCounter an interesting option.
  • Mar 13, 2013 4:39 AM UTC
thank guys ..
i will try it ..
