How to access the iteration count attribute in a FMX
  • November 20, 2020
  • 116 views
barrett_h
Hi all,
Hopefully a simple question! I have a custom transformer that I have exported to a FMX as it contains blocking transformers and looping. I want to use the iteration count value to calculate another attribute value but I cannot for the life of me work out how to access the iteration count attribute from within the workspace.
iteration_countThanks for your help.
Cheers,
Barrett
nampreetatsafe
Forum|alt.badge.img+13
@gio​  provides a strategy for accessing the "Attribute to hold iteration count" in this post: https://community.safe.com/s/question/0D54Q000080hdrkSAA/how-to-expose-attribute-iteration-count-in-a-loop
alexlynch3450
Forum|alt.badge.img+16
  • December 1, 2020
Or a simplified method could be to:
1) Edit definition for $(ITERATION_COUNT_ATTR) >
1.1) make it private parameter
1.2) set value to '_iteration_count' --can be any text, but I borrowed this value from your example above.
2) add AttributeCreator and create new attribute '_iteration_count' with attribute value = $(INTERATION_COUNT_ATTR)Screenshot 2020-12-01 134720<==1
Screenshot 2020-12-01 134832<==2
Hoped this helped!😎
