How read metadata of all items from ArcGIS Online?
  • Jun 28, 2022 12:56 PM UTC
  • 8 replies
  • 561 views
joy
Forum|alt.badge.img+17
With the help of the following request url in the Httpcaller, it was possible to get a returned xml output with information about one feature. However instead of retrieving information about one feature, ideally I would like to retrieve metadata of all the items from ArcGIS Online. Does anyone might have an idea how that can be achieved?
This url gets me metadata of one feature.
https://<companyname>.maps.arcgis.com/sharing/rest/content/items/<Item Id>/info/iteminfo.xml
Best answer by nielsgerrits
You can use the ArcGISOnlineConnector to list all items.
nielsgerrits
Forum|alt.badge.img+67
  • Jun 28, 2022 1:03 PM UTC
joy
  • Jun 28, 2022 1:49 PM UTC
@nielsgerrits​ I get the the following error when I try to browse the user content folder in the ArcGISOnlineConnector:
Python Exception <ModuleNotFoundError>: No module named 'fmepy_esri_agol'
I have ArcGIS pro and I am using the Python that is delivered with ArcGIS Pro. So I think I should be able to use this module. Do you might have an idea what might be the cause of that?
nielsgerrits
What version FME do you use? (See Help, About FME Workbench)
What is you current Python Compatibility? (See Navigator, Workspace Parameters, Scripting)
joy
  • Jun 28, 2022 2:00 PM UTC
My FME workbench isthe following version: FME(R) 2021.2.3.0 (20220131 - Build 21812 - WIN64) .
Python is 3.8
nielsgerrits
I'm not sure. It feels like the package is not installed correctly. You can try yo remove the package via the tab FME Packages under tools and reinstall it.
joy
  • Jun 28, 2022 2:28 PM UTC
You are right. Apparently I don't have enough rights to install this package. So first I have to sent a call to IT to receive the rights to install this package.
I will come back later on it when I receive the respective rights to make use of the package.
joy
  • Jun 30, 2022 12:36 PM UTC
@nielsgerrits​ I got the rights to Python and now ArcGISOnlineConnector works. I do get the necessary metadata out of the ArcGISOnlineConnector. Thank you for recommending the ArcGISOnlineConnector.
nielsgerrits
Nice. Thanks for the feedback :)
