How do i create a pivot chart using data as headers?
  • Oct 24, 2018 4:49 PM UTC
  • 8 replies
  • 112 views
Hello,
I am trying to create what I would call a pivot chart in excel using FME, I have managed to input my data which represents the number of exports from a certain area of a building by date&year; (similar to below - however my table has a lot more rows as it runs to 2030).
DateAreaNumberUnitsExported01/01/2020Area 1501/01/2020Area 2401/01/2020Area 31001/02/2020Area 1201/02/2020Area 2801/02/2020Area 31101/03/2020Area 1101/03/2020Area 2501/03/2020Area 38
Basically I am trying to get my data to look like this:
-Area 1Area 2Area 301/01/2020541001/02/2020281101/03/2020158
so that I have the date running down the side, the Area Number as the table header and the units exported in the relevant cell corresponding to the correct area and date. I would then like to export this as an excel file
How should I go about achieving this?
Thanks,
Tom
Forum|alt.badge.img+54
  • Oct 24, 2018 4:57 PM UTC
Build a list based on date, create new attributes named from the AreaNumber with the value of Units Exported, expose the newly created attributes
excel-pivot.fmwt
  • Oct 25, 2018 9:25 AM UTC
That's great, exactly what I wanted! I've noticed now that I have gaps within my original dataset
so as an example looking at the dummy data I sent in its raw format 01/04/2020 may have no records for unit exports from Area1-3 and so does not contain the three rows of data. is there a way of inserting missing rows to my final table?
Thanks
  • Oct 25, 2018 10:16 AM UTC
excel-pivot.fmwt
@egomm That's great, exactly what I wanted! I've noticed now that I have gaps within my original dataset
Thanks
  • Oct 25, 2018 10:35 AM UTC
Thanks
Are your dates always the 1st of the month and you want output in 1 month intervals?
  • Oct 25, 2018 12:12 PM UTC
Thanks
excel-pivot-2.fmwt
One possible way if you want an entry for every month
  • Oct 25, 2018 1:42 PM UTC
excel-pivot.fmwt
I realised I could have explained my problem a little better, so I have posted a separate question on the forum @egomm . Feel free to take a look - thanks.
  • Oct 25, 2018 4:19 PM UTC
Does the second example I posted not deal with this correctly?
kyrgyzkiwi
  • Jul 14, 2020 6:07 AM UTC
Thanks
This is very useful Thank you - I have one related question for folk out there.
I have a very similar situation which I'm dealing with but I don't necessarily know, in advance, how many Area Numbers there will be. has anyone had to solve such a situation?
