How do I convert .osm data into shapefile using FME?
  • Jan 12, 2023 8:37 AM UTC
  • 184 views
Best answer by david_r
Generally speaking, you'd use the OSM Reader as input and send the data to the Shapefile Writer. Depending on how you want the result structured, it might be necessary to do some further processing between the reader and the writer.
  • Jan 12, 2023 8:42 AM UTC
