How do I compare the total record count of the same 4 feature classes in 2 file geodatabases and then send a notification email if the counts are exactly the same?
  • Jun 2, 2023 6:50 PM UTC
  • 143 views
kmc5678
Forum|alt.badge.img+4
I'm currently using a file gdb reader, a statistics calculator to get the total counts, attribute manager to create fields called Today_Count and Yesterday_Count and then the conditional value in attribute manager to try and compare the two counts and return a 1 if they're exactly the same but I can't seem to get the comparison to happen. Also how do I set this up so that if the counts are exactly same I can send out an email notification?
Screenshot 2023-06-02 144201Screenshot 2023-06-02 144324Screenshot 2023-06-02 144411Screenshot 2023-06-02 144302
nielsgerrits
Forum|alt.badge.img+67
You need to get the two rows in one to make the comparison. One way to do this is to use an Aggregator. Merge attributes. Then you can use a tester to test if Today_Count = Yesterday_Count.
kmc5678
  • Jun 13, 2023 8:42 PM UTC
Thanks nielsgerrits!
