How do I build all the areas from my lines?
  • Sep 3, 2021 1:32 PM UTC
  • 270 views
hannahwh05
Forum|alt.badge.img+10
I have have been through my whole dataset and manually closed the lines in the hope that I could do a simple AreaBuilder but some areas are not being created. The yellow areas are the 'area' output port and the blue lines are the 'incomplete'. I want an area created for the section from the blue line to the edge of the yellow area. My workbench is shown below. The snapper has a distance of 1. TIAfmeQ2fmeQ
@Hannah Wheldon​ Is your Snapper Snapping Type set to Segment Snapping? If you can include a small example of your data and your workspace, someone in the community might be able help a bit more.
hannahwh05
  • Sep 7, 2021 7:52 AM UTC
I had it on end point snapping. Segment snapping seems to have worked perfectly, thank you!
