How could i force shortest path finder to go through some specific points?
  • Nov 11, 2020 5:44 AM UTC
  • 5 replies
  • 99 views
gogopotter90
Forum|alt.badge.img+14
How could i force the shortest path finder to go through some specific points ?
i have used 20 points (from to line ) , and my network .
and 10 points,i would like the path to go through them if there is a path .
i used the shortest path finder to find the shortest path and it works great but i have some points , in network .i would like to go through this point if there is a path .
as example , i have Pt.a - Pt.b (i found the path in network between A - B) but i have some points inside the network as Pt.c ,i would like to check if there is a path through pt.c or not even if it is longer .
so, if there is a path then the path will be A-C-B ,
if not ,the path will be A-B .
i think , i should add to cost attribute but i am not sure ,how could i consider the Points.
Thanks for help .
bwn
Forum|alt.badge.img+26
  • Nov 11, 2020 6:13 AM UTC
Instead of a 2 Point From-To Line, you can instead send ShortestPathFinder a 3 Point Line that is built with 3 vertices Eg:
  • VertexCreator (Replace Point) - Point A
  • VertexCreator (Add Point) - Point C
  • VertexCreator (Add Point) - Point B
Then ShortestPathFinder will attempt to find the shortest path that goes from A to B, via the intermediate point of C.
gogopotter90
  • Nov 11, 2020 6:39 AM UTC
but it means also it will try to find all option short paths from C to B or c to A ,and i do not want that .
because i have like 20 points + 10 points ,around 30 points and if i did that so it will consider the 10 points as starting point to go from .
but i do not want that ,i think it will add more paths that i do not need .
as ex. the path A-B that what i want , but if i connect all point together .so it will go from A-C but if no network to B so i do not need this path A-C .
Forum|alt.badge.img+54
  • Nov 11, 2020 8:20 AM UTC
@bwn is correct
You add an intermediate point to your from to line. If your from to line goes from Point A to Point C to Point B, the shortest path finder will return the shortest path between those three locations if possible. If you cannot go from A to C to B no path is returned, even if a path from A to C is possible
bwn
  • Nov 11, 2020 9:10 AM UTC
That is where instead using 2 x ShortestPathFinders:
1. The first ShortestPathFinder tests if a path through A-C-B exists.
2. If it doesn't, then the From-To lines that don't have a Path will output on the "No Path" port of ShortestPathFinder 1
3. The "No Path" lines then can be shortened to 2 point lines using VertexRemover to form the line A-B from a No-Path A-C-B 3 point line
4. These 2 point lines can then be tested in ShortestPathFinder 2 to test if Path A-B exists in the cases where Path A-C-B did not exist
gogopotter90
  • Nov 11, 2020 12:54 PM UTC
thanks ,i will try to do this .
