How can I use FME Data Inspector to view point cloud classifications?
I'm new to FME, and have been asked to look into quality control of land cover classification for processed point clouds. Currently, I'm hoping to use the Data Inspector to review the classification of land cover in las files, yet I can't figure out how to symbolize the point cloud by classification attribute. I haven't been able to find any documentation on this, could anyone help?
Best answer by danilo_fme
Hi @ibachmansanders, about Classification Point Cloud has a interessant Recorded Webinar about this:
How to Get the Most Out of LiDAR Data on this Webinar has the workspaces necessary to use in your case.
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • August 3, 2017
Thanks,
Danilo
Hi @ibachmansanders
If you have the point cloud classification available as an attribute you can set the inspector transformer within FME to fanout based on classification, that way you could turn off different classifications in the Data Inspector display panel.
jlutherthomas wrote:
Hi @ibachmansanders
Thanks for the tip! Would the fanout be something I build using Attribute Splitter or a similar transformer(s)? Since the point cloud is a single feature, it stores its classification values as components instead of attributes, so I can't access them with these tools.
Thanks,
Danilo
I'm working my way through this, and it's very helpful. Thank you!
danilo_fme
  • August 3, 2017
Good. I'm happy to help you :) Danilo
