How Can I remove everything after "-" in FME using string replacer?
  • February 14, 2018
  • 8 replies
  • 1945 views
Hello.
I would like to remove (replace with no text) everything what is after dash also with the dash.
What I have: test - fme
What I want: test
Cheers,
Oliwer
zzupljanin
Forum|alt.badge.img+4
  • February 14, 2018
If you use StringReplacer with these parameters, that should do the trick...
  • February 14, 2018
Thank you very much. That works. Can you please explain me that Expression so I can understand what happened there exactly?
philippeb
Forum|alt.badge.img+20
  • February 14, 2018
zzupljanin wrote:
Do you have a website in mind that can generate automatically that kind of expression?
zzupljanin
  • February 15, 2018
Certainly. So regex is a way to search through your string based on some rules. In this case rules are as follows:
\\- means "find - character"
.* means "find every character"
$ means "until the end of string"
Together they are: find every character from - character (including) until the end of string.
If you use FME 2016+ there's a really neat quick reference and testing option inside StringReplacer. With it you can create many of your regular expressions.
Cheers.
zzupljanin
  • February 15, 2018
Unfortunatelly, I'm not aware of that. There are some that give you explanation based on your expression, though.
Just to follow up on this. This is how you would remove everything located before the dash.
It took me a few minutes to figure it out so I thought I would share.
mark2atsafe
Forum|alt.badge.img+46
  • August 28, 2020
Since this question has just popped back to the top of the list, I thought I'd mention the hub transformer called LastSectionOfStringRemover, which would probably handle what the original question called for.
donegal_david
Participant
This Transformer is a Godsend... have been scratching the head until i seen your comment @mark2atsafe​ ! I've used it to extract a URL from a Name field extracted from an ESRI Story map. Cheers.
