How can i extract the x and y from csv
nath
I think i have a simple question. I have a csv where the xy is in one attribute. See example (geo_xy) but i have to do an poinonarea but because i have no x and y seperate he doesn't do it. FME doesn't recognise the geometry. I have already tried to extract the x and y by using multiple tranformers. Even used stringextractors but the number of numbers of x and y is various so it's not flawless.
I am sure there is an easy way to do it but I cannot find it.
Can somebody help me?
Thx
Nathalie
Best answer by redgeographics
The GeometryReplacer set to OCG WKT should do the trick.
  • May 22, 2020
The column looks like Well Known Text, try using the GeometryReplacer:
It will automatically convert the "geo_xy" attribute to a point geometry for you.
Forum|alt.badge.img+53
  • May 22, 2020
nath
  • May 22, 2020
Thx! It works, I never found this myself. Thank you both!
