How can i extract coordinates of this 3D GEOMETRY ?
  • Jun 24, 2023 11:42 PM UTC
  • 12 replies
  • 369 views
vimva679
Forum|alt.badge.img+11
Dear all ,
It's a hollow PIPE ,
image I want to extract XYZ for each
a) centre point (c1)
b) face centre point (v1&v2) + face INNER vertex point (vf1&vf2)
c) radius (e.g. distance from v2 to vf2)
d) total length (e.g distance from v1 to v2)
Pipe1 thank you for kind support
Best answer by hth
Hello,
have a look at the attached FME-workbench.
hth
Participant
  • Participant
  • Jun 26, 2023 6:50 AM UTC
I would start deaggregating the pipe. Vertexcount each resulting face, remove all faces with only 4 or 5 coordinates, which are the pipe walls, you don't need. Sum each X, Y, Z-coordinates and divide each by 16 to get the gravity point. Try to make 2 groups of coordinates by using neighbourfinder or hullaccumulator to seperate each ending and than sum each x,y,z-coordinate again for each ending, diving them by 8 to get the desired centerpoints.
vimva679
  • Jun 26, 2023 11:33 PM UTC
nops that didn't go well @hth​ , so i have now reduced my expectation and updated the above image with only a,b,c,d XYZ coordiantes. If you cld share me workbench that would be more helpful for me to understand and integrate into my main FME workbench / tnx 🙏
hth
Participant
  • Participant
  • Jun 27, 2023 8:46 AM UTC
Hello,
vimva679
  • Jun 27, 2023 9:17 AM UTC
Hello,
this is so excellent @hth​ , i feel more confident to learn and use more and more FME , thank you so much once again 🙂
if I want to transfer this into an excel report, i hope this is the best way to extract as i have thousands of records
Question /doubt for my understanding only, however the FME workbench you provided does a great job and extract all desired . so thank you so much for that once again .
a. you have removed the wall from pipe so ...does it remove the inner wall or outer wall and i believe we are removing the walls to extract the coordinates and get rid of solid and only have frame ?
imageb. Also you using '0', does this have some meaning to extract the inner radius ?
c. Does this Transformer play no role when we have 3D Pipe?
hth
Participant
  • Participant
  • Jun 27, 2023 11:24 AM UTC
a. It removes every wall (inner and outer), because we don't need them for the rest.
b. 0 means we take the first coordinate. 1 would mean second coordinate, 2 means third etc. To get the radius it doesn't matter which coordinate we take from the circle, because it is a circle. I just took the first.
c. I think, it is usefull, if you got different type of geometries in your data and you want to extract the pipes from it. But in the end, the pipe is a 3D-Collection of geometries. In my example I created the pipe myself without using the pipereplacer of fme. So fme doesn't know, that it is a pipe. For the workbench i created, it does not matter if it is a pipe or a solid or a collection of faces, because I deaggregate the geometry into seperate face.
vimva679
  • Jun 27, 2023 12:01 PM UTC
@hth​ thank you so much for this understanding, would it also work to relate / co-relate VF2/V2 & VF1&V1
i.e. Vf2 / V2 point are the point from the same side and Vf1 / V1 point are the points together of the other side as well ?
the reason i have to then after calculate Face and Longest Direction based on those respective points .
vimva679
  • Jun 27, 2023 12:35 PM UTC
I think i found it that itself in the FME workbench you provided, there is that relation / co-relation of points . thanks a lot @hth​ image
daveatsafe
Forum|alt.badge.img+24
  • Jun 27, 2023 7:57 PM UTC
Hi @vimva679​,
I have attached a workspace that uses a bit of a different approach, but will get you the same answers.
daveatsafe
  • Jun 27, 2023 8:04 PM UTC
Bonus workspace to extract the Pipe centerlines with inner and outer radius values.
vimva679
  • Jun 27, 2023 10:27 PM UTC
Hi @vimva679​,
thank you @daveatsafe​ for that extra mile , am truly thankful for it .
vimva679
  • Jun 28, 2023 12:59 AM UTC
I am truly thankful to all Safe Support team, @daveatsafe​  and @hth​ , @nampreetatsafe​ for such smart solution and promising support, its just also helped me to save some major errors that i could easily made as beginner. The current transformers turned my workflow very efficient. So thank you once again for solution and that too on time bound and crystal clear steps that remarkably fitted so well into my main FME workbench without any error.
vimva679
  • Jul 5, 2023 12:36 AM UTC
EATR_workflow2If there is any better way to extract desired point, either of the above FME workbench could be appended to extract this feature as well. Please note the FACE of the Circular has thickness and front facing coordinates need extraction
