How can i create autocad blocks without a template file?
  • Oct 7, 2021 1:31 PM UTC
  • 216 views
So im reading the dwg file to fme, than just want to put it out to elswhere, while converting the elements to an autocad block. The problem is that no matter how i parameter the feature writer, it messes up the output dwg file.
So the elements need to look like this:
CaptureBut after writing out to the new dwg they look like this mess:
Capture2I also put the feature writer parameters here:
Capture3I tried to aggregate the features, in that case this problem doesn't occur, but than i loose all the colors and other attributes, which is not an option.
accur
Participant
  • Participant
  • Feb 2, 2026 1:20 PM UTC
Hello vargaaadam,
I know this is an old question, but I am currently using FME 2022.2 and I am experiencing exactly the same issue.
Did you manage to solve this problem at the end?
