How can i count how many TRUE and FALSE are there in each ROW ?
vimva679
Forum|alt.badge.img+9
Please appreciate if you could let me know in details
Best answer by ebygomm
If all the attributes with true and false values end in ZTF I would use a ListExpressionPopulator with a Source Attribute Expression of ZTF$ to get all the true false values in a list, followed by a ListHistogrammer which will then count the true false occurrences and return the results in a list
imageYou can then turn the list values into attributes
nielsgerrits
Forum|alt.badge.img+55
One way to do this is to explode all attributes to features, merge and count the results.
  • AttributeExploder to create features from all attributes.
  • AttributeFilter to filter only features where value is true or false.
  • Aggregator to merge and count all features grouped by row id and attribute value.
  • FeatureMerger to merge the results back to the original values on row id.
Forum|alt.badge.img+39
  • May 26, 2023
vimva679
  • June 6, 2023
thank you all it works :)
