How can I convert XML file to shapefile (Arcgis Pro) ?
  • Aug 10, 2022 3:40 PM UTC
  • 3044 views
Good day,
I tried to convert XML file to shapefile using FME and using the same steps in safe website but the data did not show up in the map and the shape was point, and what I was expecting is line.
Here is the data source of XML:
OneGeology catalogue (brgm.fr).
Thank you with kind regards,
Majdi
Best answer by rahulsharma
Hi @majdi​
Please find attached the workspace.
Hopefully, it helps. I have used WFS to Shape, but the link that you have share appears to be a WMS service.
rahulsharma
Forum|alt.badge.img+12
  • Aug 10, 2022 8:21 PM UTC
Hi @majdi​
  • Aug 12, 2022 9:19 AM UTC
Hi @majdi​
Dear rahulsharma,
Thank you for your help. Yes, the link has WFS and XML and ZIP files in the top right of website (download) I tried to us that.
I used your file and it works but not for Germany as you can see in the attached screenshot.
Is there something I can do to solve this problem?
Thank you again with kind regards,
Majdifaults
  • Aug 12, 2022 10:26 AM UTC
Dear rahulsharma,
I solved the problem by increasing ''Max Features'' in the parameters of (WFS).
Thank you with best regards.
Majdi
