How can I convert CityGML Files into clean OBJ Files?
  • Jan 7, 2022 3:56 PM UTC
  • 864 views
Hello FME-Users,
I have a problem with my CityGML Data. I want the final results to look like clean OBJ Files. When I load them into e.g. 3Ds Max they should have no errors. I also do not want faces to be seen in my 3D software. Instead I would like to see proper polygons (if quads are possible, I want to see them; they can be made out of triangles, but these triangles should be hidden).
I found this image on Wikipedia showing the different possible Elements of a mesh:
 Mesh_overview
My current FME workflow looks like this:
workflow
I have buildings made out of 3 elements: Groundsurface, Wallsurface and Roofsurface. I would like to bring all of these together as a mesh (with polygons). I used the GeometryCoercer to convert the rawdata into polygons. The MeshBuilder is used to create a mesh. Here I think my polygons were converted into surfaces...
Below I also provide you with my settings from the Deaggregator and the Coerser.
deaggregatorcoercer
In 3Ds Max the buildings look like that:
3dsmaxthis looks really faulty... The files are not really usable in a 3d software.
I would be very thankful, if anybody could help me with this problem :)
  • Jan 7, 2022 9:24 PM UTC
Hi @christianlendl​ , I think OBJ writer has a capability to aggregate automatically input surfaces/solids into a single mesh before writing. Have you tried this workflow?
citygml2obj
  • Jan 8, 2022 10:09 AM UTC
Hi @Takashi Iijima​ , thank you very much for your fast reply!
Yes I have tried this workflow as well. Unfortunately the results are not really different from the workflow before...
In the viewport of FME everything seems to be fine, but when I open the files with 3Ds Max, they still look very faulty.
fme_testhere I have the view from FME.
And here from inside 3DsMax...
3dsmax_new
Something has to be very wrong with the files, because I can open any other obj file (not generated with FME) and everything seems normal in 3Ds Max.
Thank you very much for your help in advance!
